envelopes
  • luis8832
    • Dec 2008
    • 250
    [Misc] envelopes
    Working on a km-3050, when the customer received the unit i showed them how to print labels and envelopes. Now the envelopes dont print properly. The address in the corner of the envelope only prints half and i get a black line on the envelope. If i put an 8.5 x 11 sheet of paper and print as if it were an envelope the address comes out fine. I have checked all the rollers, they are all fine. Swapped out parts with another km-3050. Still same outcome. Any ideas would be appreciated as to i am at my wits end with this unit(AAAAARRRRGGGGGHHHHHH).
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    Re: envelopes
    Paper setup in the software has to match printer driver and MP tray setting on the actual machine.
    Is this file based on a envelope template?
    Idling colour developers are not healthy developers.
    • luis8832
      • Dec 2008
      • 250
      Re: envelopes
      they all match. as stated earlier it was working fine before. i am attaching a scan of the envelope.
      • jmaister
        certified scrub
        • Aug 2010
        • 755
        Re: envelopes
        edit: nvm, was looking at the problem in the wrong direction...sry. Did they happen to get newer Mircrosoft Office?
        • nmfaxman
          • 1702
          Re: envelopes
          Program the bypass to custom size envelope.
          I hav had customers use the same envelope for years, then all ov a sudden it won't print.
          Quick trick is that the glass has rulers on the outside.
            • 23009
            Re: envelopes
            Just came across this problem this morning, but I don't have any good answers.
            They're using Microsoft Word as their envelope template, and like a lot of Microsoft Office programs it offers only certain driver choices when using templates, and overrides the printer defaults.
            My only useful suggestion was to create their own template document, custom sized 4 1/8 x 9 1/4, and not use the built in envelope template. Then you get all the print options, including COM10 envelope size, envelope media type, and top tray (face down) exit.
            Once you get these print options it works OK.
            Oh, and my customers problem was that the envelopes exit to the DF-710 tray A, which jams every time. That's where Word wants the envelopes to go, and blocks choosing the output. =^..^=
            • mojorolla
              The Wolf
              • 2627
              Re: envelopes
              Personally, I hate envelopes. The air get trapped inside and you get back CQ or creases. The corners of the envelopes are the key. If they overlap too much, the air is trapped inside causing image issues. Has the customer changed envelopes recently? The ones I have found run the best have corners that meet at the tip of each seem and have little overlap on the corners.
