Kyocera KM 2540 error code C7400
  • aborad
    • Aug 2011
    • 61
    [Error Code] Kyocera KM 2540 error code C7400
    please help me to resolve C7400 error in Kyocera KM 2540 Printer.
    in manuals its showing to refix connector so i have tried with that also replaced Developing unit but problem not resolved.
    please help to resolve this error.
    • 22999
    Re: Kyocera KM 2540 error code C7400
    You can pin out the harness from the developing unit PWB to YC1 on the engine PWB. I'd say the chances are pretty slim that you'll find the problem there.
    You'll probably end up changing the engine PWB. =^..^=
    • aborad
      • Aug 2011
      • 61
      thanks BlackCat.. harness pins connectivity is fine... now may be problem is in Engine PWB.. can u please give me part no. for the engine PWB.
        • 22999
        The Copystar number is: 302JB94080
        I am 95% sure that the PWB is the same used on both Copystar & KyoceraMita, only the OEM purchaser is set differently. Simulation U265 set to "2" for KM, set to "66" for Copystar, (there are other less common like Utax, but I don't know those). =^..^=
        • aborad
          • Aug 2011
          • 61
          thanks blackcat. i regularly visit your thread and i m impressed the way you reply to people..once again thanks a lot..
            • 22999
            I'm glad to help. =^..^=
            • aborad
              • Aug 2011
              • 61
              i have replaced Engine PCB even though not able to resolve problem.. i have notice that Developer no. is not showing in maintenance mode.
              please help.
                • 22999
                Have you re-loaded firmware after the board replacement? New boards rarely have current/compatible firmware.
                Is the developing unit you installed the correct type? Check the part number to be sure. =^..^=
                • aborad
                  • Aug 2011
                  • 61
                  i have not re-load firmware.. i don't have firmware.. if you can provide me then i will be thankful to you.
                    • 22999
                    I do not provide firmware, but maybe Paul can help: Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads > Chat
                    • aborad
                      • Aug 2011
                      • 61
                      Hi... finally problem solved by replacing Power Supply (SMPS)..
                      thanks for help me..
                        • 22999
                        Thanks for posting back. Maybe this can help someone else. =^..^=
                        • habik
                          • 2013
                          OEM destionation code is
                          Olivetti - 12
                          Utax - 11
                          KM - 2
                          in case someone is in need.
                          Cheers
                          Habik
                          Firmwares HERE
