fax issues on a FS-3140 mfp
  • luis8832
    • Dec 2008
    • 250
    Seems to only happen sometimes. The customer claims not to be receiving all their faxes. I experienced the issue before and turned off ecm and v.34. Everything was ok until 2day. The customer missed 2 orders because they did not come through. It is a dedicated fax line, any suggestions will be appreciated.
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: fax issues on a FS-3140 mfp
    What does the activity report say? Perhaps they need a second fax to handle the traffic.
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • tlf
      • 39
      make sure they do not have call waiting on that line( when it beeps at you when you are still on the phone line.) also are they using voip phone lines?
        • 23009
        Originally posted by Venom
        What does the activity report say? ...
        What errors?
