kyocera km 3060,can switch on bt can nt process to make copies,its a new machine.
  • RWAFA
    • Aug 2011
    • 68
    [Misc] kyocera km 3060,can switch on bt can nt process to make copies,its a new machine.
  • JustManuals
    • Jan 2006
    • 9838
    Re: kyocera km 3060,can switch on bt can nt process to make copies,its a new machine.
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Paul@justmanuals.com
      • 23010
      Alex, I'd like to buy a vowel. Maybe a couple ...
      But seriously, you're going to have to be a lot more specific before I can help you.
      1) What function are you trying to use that does not function?
      2) What messages are displayed on the screen?
      3) Are you familiar with the basic operation of the machine? (Do you have little necessities like toner, paper, electricity, etc...)
      • RWAFA
        • Aug 2011
        • 68
        NO masage is comng on,aftr swtng on just show kyocera,from there the display switchs of as it is on stand-by,frm there no any key enters.
          • 23010
          It sounds as thought the firmware is corrupt, and possibly more.
          Start by reloading or upgrading to firmware 2.49 dated 6-27-2011.
          No, I'm not going to give it to you. Maybe Paul has it. And while you're at it you should probably get the service manual. That way you can learn how to load firmware all by yourself. It's not hard. A mere two pages of reading, and a CF or USB memory (either one is fine).
          Now is your chance to show some independence and try to figure out this part by yourself (www.justmanuals.com)
          Depending on the results of your firmware flash, it may be fixed, or you may have to do more. At the end of the firmware flash you'll get the "Completed ... " screen. Pay special attention to the results. Completed is good. No Change is fine (it just means that that particular firmware file wasn't in the combined packet or you don't have that accessory). Failed is not so good. Pay attention to the Failed ones.
          If you come back sounding like you tried, I'll be glad to help. If you just wimper, well then it's just up to you. =^..^=
          • RWAFA
            • Aug 2011
            • 68
            I received 2 machines of the same model,this one with problems my junior tried to instal it,he switchd on without unlocking trays,could it be the problem?the other one is workng perffectly.
              • 23010
              No. Leaving the tray plate locks on will create C1010 and C1020 errors which will display temporarily on the screen. You can reset those errors in service mode, simulation U906 (also in the service manual). =^..^=
              • RWAFA
                • Aug 2011
                • 68
                Re: bizhub 162,machne makes a good copy,bt the prblem comes when coping back to back.
                when coping the back side of the copy it comes out faint as if there is no dev-bias or as if transfer is weak only when i turn the copy.the machine doesnt have duplex.im nt too familiar with this machine.
                  • 23010
                  Have you solved any of the previous problems we've discussed?
                  Which machine is this? The one with the firmware problem or the one with the cassette lift problem?
                  It sounds as though a peek at the Installation Guide would have helped a lot. =^..^=
                  • RWAFA
                    • Aug 2011
                    • 68
                    thnkx Blackcat,that 1st 1 i havent fixed it,the machine is bit far from where i am now,this 1 is a minolta bizhub 162.
                      • 23010
                      You should create a thread in the Konica Minolta forum. And it's a good idea to identify the manufacturer and model of the machine you are working on. I'm not very good at guessing. =^..^=
                      • Hemlock
                        • 432
                        Anyone else expecting this?
                        “Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'” (Isaac Asimov)
                          • 23010
                          Isn't that a Mita DC-3060? Haven't seen those in ages.
                          • RWAFA
                            • Aug 2011
                            • 68
                            no Black,its a kyocera km3060,i did also these mita u are talkng abt.
                            • Hemlock
                              • 432
                              For analog boxes, they really weren't that bad.
