FS-C2126 MFP
  • sOUner
    • Oct 2010
    • 4
    [Misc] FS-C2126 MFP
    Showing "toner is running out (M)", even after replacing (M)toner. There is no excess (M)toner in waste container. Also happening on FS-C5100 Series printer.
  • JustManuals
    • Jan 2006
    • 9838
    Re: FS-C2126 MFP
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
    Paul@justmanuals.com
    • cbs
      • Apr 2011
      • 86
      Re: FS-C2126 MFP
      I've seen this issue on a FSC2126 and C5150DN printer as well. KMA issued a tech bulletin that clarified the issue. Basically, the toner cartridge drive gears aren't "latched" and you have to rotate the cartridge gear back into a latched position. Re-install the cartridge and it should work.
        • 22999
        Re: FS-C2126 MFP
        Now that you mention it, on the 5100 series I've noticed that the cartridge linkage does not home exactly to the specific position required for a good mechanical connection. The drive seems to home to a position ~15 degrees beyond home. I have educated my customers to turn the coupler on the cartridge ~15 degrees, and it will engage. =^..^=
