Scanner Coin Box
  • kyoceradude
    The Great Gazoo
    • Aug 2006
    • 442
    Scanner Coin Box
    I was just asked if you can hook up a coin box to a Kyocera product and charge for scans.... Anyone come across this? Is it possible?
    My mission here on Earth is to help all you Dum-Dums!
  • DotsOnPaper
    I don't see any reason why not. You would simply add the coin box like you would a keycounter. Don't forget to enable maint mode 204. The Coin box would enable/disable the entire machine eg copier/printer/scanner. Not knowing the intent of the end user, I speculate you would either (A) need a pc connected next to the MFP to plug a thumb drive into or (B) scan to e-mail set-up to deliver the scan to a portable use.
    Hope this helps.
      • 23009
      I agree, It seems plausable. My concern is that there may be no way to obtain a count down signal to decrement the coinop. Usually the reg clutch or exit sensor are used as a count down signal, and neither would be used in scanning. Your only hope is that the controller kicks back some sort of count down signal. Maybe you could use scanner home position switch as your pulse?
      Let me know how this works out. This is just the sort of impossible thing that my sales department would want to happen.
      • just a tech
        • Jan 2007
        • 332
        we've got a couple of copystars with coin boxes..none of ours have scan options though..but i don't see why it wouldn't work with the proper set up..once the copier is enabled, i would think there wouldn't be any difference between copying,scanning, or otherwise.. the coin ops we use are from Vendapin LLC .. when using the coin-ops, ya have to enable maint. mode #206.. website for them is "vendapin.com" ...hope all goes well..
        • kyoceradude
          The Great Gazoo
          • Aug 2006
          • 442
          That wouldn't work because of the doc feeder. Unless they don't sell it with a doc feeder. 1 scan at a time. Hmmmmmmm. The customer want's it to vend for each page scanned, copied and even printed. We're talking about Kyocera Mita Falcon III's. They even want to talk about color machines...
          • wagon
            Village Idiot
            • Dec 2006
            • 654
            With a 'small' amount of electronics you should be able to use a signal from a clutch in the doc feeder. As for printing/copying also, maybe a signal from the mechanical counter can be integrated in?
            I built the first (for Australia) card reader interface for the CF3102 - using a whole stack of logic chips. A nightmare, but it worked.
            If you are hitting your head up against a wall it always feels better when you stop.
              • 23009
              Wagon,
              No mechanical counter on a Falcon III. Only digital. You could still use the reg clutch or exit sensor for prints & copies. It's the scans that's perplexing...
              • qbert69
                • Mar 2013
                • 1152
                CONNUNDRUM REVIVAL!!!::Re: Scanner Coin Box
                I don't know how to flag this one, but our "sales" department recently made a sale to a local university of several Kyocera 4550ci and 3550ci machines...Two (2) of those machines have coin ops attached. The university establishment wants to make "free" scans available to the students. The only problem is, to enable the machine interface (remove the "deposit coinage") screen block, you have to deposit 25 or 10 cents!....You can then use the scanner without being charged and you can get your money back by pressing the refund button on the coin op machine! The IT head sees this as an extra "hassle"...Is there a way to enable the scanner without coinage deposit???
                My thought is no, since the coin op acts as a bouncer at the entrance to a bar taking a cover charge!
                Gotta pay to play!....Just in case you decide to make a copy!
                Any other thoughts Senior Copy Techs?
                Thanks in Advance for ANY INFO!!!!
                REACH FOR THE STARS!!!
                Konica Minolta Planetariums!
                  • 23009
                  Maybe some sort of Hypas App can be written, but that won't be free. That will add a cost to the sale. =^..^=
                  • ktucker
                    • Apr 2012
                    • 23
                    We have a TA 4053 setup with a ITC coin op
                    the customer wants Free scans .
                    has anyone seen a way to allow scanning from the panel without inserting coins.
                    the Sharp Boxes did not restrict scanning under vendor control.
                    • craigster
                      • Apr 2016
                      • 201
                      I have a coin op on a 3252ci and the only way to scan is put coin in to enable machine. I have this one set up to print a conformation page otherwise it sits there waiting for something to be printed. No way to program it for scans cost.
                      • Scottb
                        • Apr 2013
                        • 307
                        if scanning to a pc folder there is a option for a result print...to trigger that the job finnished
