km 4035 machine eror
  • eurokris
    • 120
    [Error Code] km 4035 machine eror
    hi greeting to all
    km 4035 came eror code c6420.already check fuse and termistor .everything is ok.
    how to repair the main controller pcb.pls anyone give infomation.
    thanks
  • aabarnes1
    • Mar 2009
    • 620
    Re: km 4035 machine eror
    Originally posted by eurokris
    hi greeting to all
    thanks
    Reset fuser error in simulation mode
    Grant me the serenity to accept the things I cannot change.
    • eurokris
      • 120
      already try reset u163 and u906.but same.
      thanks
        • 22930
        Fuser Unit Fuse Cut Problem. The fixing temperature remains at 0C/32F for 30 sec continuously when the fixing heater is On. 1) Read resistance across thermistors. If infinite resistance replace thermistor, 2) Check YC10 @ main PWB, 3) Pinout harnass.
        It's either the thermistors, the harness, or the main PWB. Those are the choices, in that order. Have you done a U163 fuser error reset?
        You won't find many techs nowadays that will attempt board level repairs. The components have gotten so small that you can hardly see the damn things, let alone handle them with any degree of confidence. If it comes down to the main PCB, replace it. =^..^=
