Kyocera KM-3035
  • clearview
    • May 2025
    Kyocera KM-3035
    Copier will not save settings but automatically copies and prints to 51/2 x 81/2. Also fax section will say it's going to fax 81/2x11 then as its sending swiches to 51/2x81/2. How do I fix this.
    Another note, I do not have the password.
    Help please!
  • marc
    • Feb 2010
    • 56
    Re: Kyocera KM-3035
    Those setting you have to changed in the printer driver go to printer preferences-basic-and select print size letter 100% about the password I don't khow which one the one for machine default is 3000
    • clearview
      Re: Kyocera KM-3035
      The preferences are set to 100% any other ideas?
      • marc
        • Feb 2010
        • 56
        Re: Kyocera KM-3035
        go to default setting-machine default-select paper size-change to auto detection unit inch
          • 22930
          Re: Kyocera KM-3035
          Help please!
          Are you saying that the scanner always identifies the original as statement-R? =^..^=
          • Metalvoc
            • Sep 2008
            • 155
            Re: Kyocera KM-3035
            You've got an original size detection problem. you can try switching out the sensors in there. You might even be able to figure out exactly which one it is by using sim 99
            I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain
            • clearview
              Re: Kyocera KM-3035
              is this on the printer itself now or a setting on the computer?
              sorry - no experience, my boss is trying to avoid payine $200 for something simple :S
                • 22930
                Re: Kyocera KM-3035
                So answer my question, please. =^..^=
                • JustManuals
                  • Jan 2006
                  • 9838
                  Re: Kyocera KM-3035
                  Paul@justmanuals.com
                  • clearview
                    Re: Kyocera KM-3035
                    Sorry, customers...
                    i have no idea what you are talking about...
                    • clearview
                      Re: Kyocera KM-3035
                      any one else have some advice! ps- you are talking to someone who knows nothing about printers/copiers except to push start!
                      • habik
                        • 2013
                        Re: Kyocera KM-3035
                        Is your copier under fluorescent light OR any other rather bright light?
                        This is what usually messes up the OPTICAL sensors.
                        If the width is the issue than just dis-assemble the feed tray, and clean any dust/ rubbish that may affect conductivity on the copper brush. Don't worry about lube as there is plenty left, you can easily wipe it off.
                        Just lift it up to vertical position and from under neath you can see I think 4 screws that are holding the unit together..pretty easy job.
                        Let us know if this was the case.
                        Habik
                        Firmwares HERE
                        • jummamaster
                          • Mar 2009
                          • 99
                          Re: Kyocera KM-3035
                          If you know nothing about technical details, call a technician. It would be the best solution in my opinion.
                          Ricoh Error Codes
                          Canon Error 5100
                          Canon Error B200
                          j
                          c
                            • 22930
                            Re: Kyocera KM-3035
                            Truly. Our goal here is to assist individuals to solve problems. Not to give away technical expertise, and teach unwilling individuals with no background or initiative to be technicians.
                            When I hear "Don't explain it to me, just tell me what to do.", that's when I'm finished. Call a tech. =^..^=
                            • kyocera10
                              • Sep 2011
                              • 13
                              Re: Kyocera KM-3035
                              wrong casette detection, there must be something a piece of paper or anything in the sensor
