F-000
  • tech.gasm
    • Sep 2010
    • 39
    [Error Code] F-000
    I'm at a client who has 5 TA-420i & 5 TA-400ci.Problem is I do get the F-000 error code at times particularly on the TA-420i & on the service manuals,there's no reference to the mentioned code;At times when the mfd is in sleep mode,you will find the red/orange LED will be flashing,touch screen-off & any attempts to resuscitate the machine short of a restart will not do. Any ideas anyone??
    • 23003
    Re: F-000
    F000 = cf000 = Operation Panel Communication Error
    If you're lucky, just a firmware upgrade can resolve this. If you're not so lucky it can involve the CODE DIMM (DIMM memory that holds the firmware @ YS1 on the main PWB), the HDD, the operation panel PWB, or the main PWB, or some combination of the above (in that order). After each attempt you'll need to re-load the firmware (or attempt to). Pay special attention to the final "Completed ... " screen. This is where the machine will tell you which firmware failed, and where to go next. =^..^=
    • JustManuals
      • Jan 2006
      • 9838
      Re: F-000
      Paul@justmanuals.com
      • tech.gasm
        • Sep 2010
        • 39
        Re: F-000
        Thanks blackcat4866,I'll get on it.
