I have a brand new kyocera km-2560. I found running 24lb envelopes that they do not wrinkle. The problem I have now is that the return address is being cut half off. The only fix I have found is to move the address way over. It is almost like there is a lead edge issue with the bypass. I have tried different software and designs, all with the same result. Any ideas?
Envelope Alignment
Re: Envelope Alignment
I'd guess it's one of the edge erase settings in tech mode.“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'” (Isaac Asimov) -
What paper size is the MP tray set to? If you are not set to the correct envelope size, it may still print, but cause your document to be cut off, or print in the wrong direction. You could also try setting your KX driver to a different emulation. Sometimes PCL5 or KPDL may create a more desirable result. Worth a shot.
What brand of envelopes are you running? I have always had trouble with Kyocera printers creasing, and normally running envelopes with a straight flap will alleviate the problem, but if you have found one that works well, I'd love to know what it is!I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark TwainComment
Like Metalvoc says, envelopes are always a problem. But if the media size and type are set correctly, the leading edge registration can be adjusted separately for the MP tray in simulation U034. Perhaps this or the loop adjustment would help. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
Metalvoc, my customer had a bad wrinkling problem in the beginning with recycled envelopes. I found an old box of 24lb office max brand envelopes and took a stack in there and they ran great. The odd thing is, the first envelopes they were running lined up perfectly but wrinkled. Then they started misaligning and wrinkling. I don't think the brand is super important, just be sure they are 24lb. Kyocera recommends KENTWOVE brand but they are rather expensive. Most of your basic stores don't sell 24lb and if it is not specified then they are not.
I have double and triple checked all of the size settings. I will however today go into the settings and make sure that the MP tray is set for #10 envelopes. I have found difficulty with the interface and how to make changes with this machine but thats probabaly because I am new to Kyocera.Comment
