taskalfa 820 jams p 82 only drawer 2
  • tlf
    • 39
    This machine has a 1.2 mill started jamming only in drawer#2 deck and only when you staple. will run about 3 to 8 pages in the staple stack tray and then it will jam 82 . no jamming in drawer 1 and drawer # 2 jams only when you staple it will run with no jams if you don't staple. Replaced all the tires and 1 way bearings. called tech support and no help at kyocera The pages jam at the finisher entrance at the first delivery roller and the paper is not in the delivery roller itself any ideas?
    • 22930
    Re: taskalfa 820 jams p 82 only drawer 2
    The only thing that makes any sense to me, is that perhaps you're getting a mild paper skew from tray #2 pickup that doesn't snag up until it gets to the finisher. If that was indeed the case, the printed image on those pages would be slightly askew. It's something you could test for.
    I don't have any of the CS-820's in the field, but I do have their predecessor the CS-8030. You might look at the mylars around the separation roller. They're known to wear. Please let me know what you find. =^..^=
    • aabarnes1
      • Mar 2009
      • 620
      Does it happen if you perform the task from tray 1 or 3 or the mp tray, if it doesn't then your looking at a time out issue from tray 2. There are 2 sensors on the feed deck, take them out and put an extra turn on the spring on the sensor arm and do the same to the exit sensor, just after the fuser. Fixed most jams for me. Blackcat is right about the mylars aswell, although they are different int the 820 than the 8030.
      Grant me the serenity to accept the things I cannot change.
      • Copystar Tech
        • Sep 2010
        • 59
        I am about to post a similar (but not quite) problem in the forum. When stapling or offset sort, the machine used the siding roller to store pages. It's the big one that lifts up with the cover. The are two sensors, one to the left of the roller, just below sub-tray exit, and one under a spring loaded plate just prior to where the hole puncher would go. The one under the spring loaded plate especially likes to collect dust. Make sure these are clear. No off to post my problem. Good luck.
        • tlf
          • 39
          status update plugged a other finisher on the machine. work fine no problems orderd selnoids a b c will let you now what happens.
          • tlf
            • 39
            update on ta 820 replace a b and c selnoids has worked with no service calls in about 2 weeks ( in a high volume school location)
            • Elmdale
              J82 is usually the first page has not been deflected around the buffer roller in the finisher, if you replace the solenoid for the deflector in the finisher p# 3H327420 it should fix the fault.
