C2770 on Alphard Venus (CS-4550ci)
    • 22999
    This one is so dumb I just had to share. I didn't discover the fix. Credit goes to Big Fat Pauly (you know who you are).
    The C2770 error is a transfer belt shift error. On the new Alphard series, the transfer belt has a mechanism to center the transfer belt, in case it starts to walk off one side of the pulleys. And it works great until you install the AK-730 bridge unit.
    On instruction 19. they tell you to install the front left stay with the 20mm long black screws. If you follow that instruction the bottom screw will press against the transfer belt cleaning unit, preventing it from self-adjusting, and forcing the belt gradually off one side. The fix is laughably simple. Install 12mm long screws for the front left stay.
    This was discovered in class. You know how after 10 or 20 disassemblies the test machines end up with all the wrong screws in the wrong places? The 30mm long screws for the latching bracket caused an immediate code C2770. With the 20mm long screws it takes about 15K prints to walk off it's pulleys, but same affect.
    How dumb. =^..^=
  • correo.tony
    • 72
    Re: C2770 on Alphard Venus (CS-4550ci)
    intelligent appreciation
    • Metalvoc
      • Sep 2008
      • 155
      wow, thanks for posting that. That sounds like the kind of problem where I would have spent the afternoon beating my head against a wall!
      I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain
        • 22999
        Update: I ended up replacing the TR-8505 transfer belt assembly today. It has again 5mm off center.
        If it wasn't under warranty I would have busted my way into the belt shifting mechanism. But alas, I have to return it. When I get one to the maintenance interval I'll dig into it. I seem to recall from class that there is a small DC motor with a worm gear drive.
        An interesting side affect is a J2316 and a J0000 accompanies each C2770, all with exactly the same count on the Event Report. =^..^=
        • Metalvoc
          • Sep 2008
          • 155
          The jam code is referring to a conveying sensor, which would make sense if the device was printing when the error occurred. The J0000 with the same meter would be likely if the customer tried to fix the problem by turning the machine off/on with paper still jammed inside.
          So you are saying it may not have been due to the interfering screw in the attachment kit?
            • 22999
            For me, the screw may not have been the cause, or the only cause at any rate. I really would have liked to examine the mechanism more closely, but didn't want to void the manufacturers warranty. The belt had walked 5mm off center, to the rear I think.
            The next time you pull the transfer belt, take a peek in the opening. You can see the screw. And it is a good 8mm longer than it needs to be. And there isn't much room to spare. I can see how it would be a problem. =^..^=
