Error CFB30 on km-3060mfp
  • kooolio
    • Sep 2011
    • 1
    [Error Code] Error CFB30 on km-3060mfp
    Hi
    Got a km 3060 with non responsive touchscreen (board with dimm on it). got a replacement op panel (without dimm) and is getting a cfb30 error code on boot up. Suspect something to do with firmware but unable to locate latest firmware, any help would be appreciated.
    thanks
  • Metalvoc
    • Sep 2008
    • 155
    Re: Error CFB30 on km-3060mfp
    From Tech Bulletin 3 on the 3060:
    When upgrading Firmware to MAIN/MMI2 Ver. 11.006 (2.05A Combined Firmware) on an MFP with the New Type Panel PWB installed, a Server Error message will display when the MAIN/MMI is Ver.10.029 or below. The MFP must be cycled OFF, wait at least five seconds, and then cycled ON again. The Firmware upgrade will start and the Firmware will be upgraded successfully. A Compact Flash must be used for this Upgrade. USB is not supported for this Update. Compact Flash or USB can be used for subsequent updates from Version 11.006 and above.
    If you try to downgrade Firmware below MAIN/MMI2 Ver. 10.029, on an MFP with a New Operation Panel 2 PWB, a CFB30 error will trigger. If this occurs, load MAIN/MMI2 Ver. 11.006 (2.05A Combined Firmware or above) to recover from the error.
    The firmware should all be available on KMAconnect
    I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain
      • 22748
      It might just be that the panel is not at a compatible level of firmware to talk to the main firmware. Whenever a board is changed a firmware upgrade is necessary. =^..^=
