Hi I would like to ask is i can still use the toner on the toner disposposal tank? What will happen if i use it again? What is the technical explanation for this? Thank you very much.
It's not a good idea. It's not just waste toner. You end up with other contaminants that don't produce any image, like room dust, and paper dust.
You don't get the degrading affects of undertoning because the FalconII is mono-component. But you will get poorly developed areas. =^..^=
