Black copies are usually caused by primary charge loss. Rather than just verifying, you might start by replacing the primary charge unit. And check that the drum drive coupler is not gummy, causing a poor drum ground. =^..^=
I had that problem before, I replaced the drum ass'y with the main charger and no fix after I reset the all memory with the simulation 20 and 21 the copier started working ok, but also this machine was geving me a error memory full that was fixed after i did that I hope this help.
salvation I have one km 2530 when I print the page is completely black I verified drum and corona ??????????????
hello friend l can help you ...we have the service manual for this km2530 also l live near your location ..call me by my phone ..l can repaired your km2530
