kyocera 4035 management codes
  • pfinn10
    • Jun 2010
    • 46
    Customer uses user codes (management) to keep track of copies/scans etc. The technician removed the HDD (the back one) and put it back in and now i've got no codes, is there anyway to retreive the codes?
  • Metalvoc
    • Sep 2008
    • 155
    Re: kyocera 4035 management codes
    If the codes are not appearing, then probably not. Is this the same HDD? If so, and your management codes are not showing up, then I'm guessing the other tech probably formatted the drive, as well. If you turn on the management mode, and there are no codes there, I think they are gone. Maybe someone else will have better news for you, but that is my understanding.
    I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain
    • Shadow
      PHD in Sh!t Disturbing
      • Sep 2011
      • 455
      Yes, Metalvoc, you are right. If the drive has been removed and formatted or placed in an other machine for testing, then your managment codes are gone. Did the tech not do a backup of the drive before he removed it from your machine? He should have in order to avoid issues like this. Have the Tech return to redo the programming for you.
      $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
        • 22999
        In defense of your tech, if there was a hard drive failure, there would be no way to back up your job accounting IDs. The information is just lost. If a backup had been made on a previous occasion, that backup could be imported. =^..^=
        • Shadow
          • Sep 2011
          • 455
          if the initial service call indicated a HDD issue, then yes there is no way to do a backup. however the 1st post indicated that the drive was removed and then reinstalled, I do believe that there is more information from the user that is not yet present. There is software for the end user so that they can make the backups of their machine hard drives. an ounce of prevention is well worth the 5 pounds of cures.
