Kyocera Mita KM-2530
  • tcypy1961
    • 773
    What would cause the exit rollers on a Kyocera Mita KM-2530 not to turn and feed the paper out of the copier? Any help appreciated, thank you.
  • Metalvoc
    • Sep 2008
    • 155
    Re: Kyocera Mita KM-2530
    You can test the eject motor both forward and back in sim U030. If the motor turns in simulation, you probably have a bad sensor, which you can test with U031.
    I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain
