Export address book from KM - 3050
  • MFPTech
    • 486
    Has anyone exported / imported the address book from KM - 3050 please? What format is the file, csv or Kyocera native format? If it's csv is there any particular order of the name, last name, email address, fax number, etc.
    Haven't tried yet but looked at the Command Center operation guide and didn't see the export option.
    Thanks in advance!
  • dikyo
    • Apr 2011
    • 45
    Re: Export address book from KM - 3050
    The adressbook can be im/exported with U917 to an USB-stick.
    Also you can use the KM-netviewer utility.(when you want a csv-file)
    • luis8832
      • Dec 2008
      • 250
      You can export on a usb stick and then import to new mfp. Very simple, easy and quick. Done it many times. Saves a ton of time. U917 in service mode.
        • 23009
        You can edit the file with the utility, but it's encrypted, so I don't think you can open/read/edit with any other application. =^..^=
        • MFPTech
          • 486
          Used 917 for import / export; also found that KMNet Client does editing
          Thanks for the replies.
          • MFPTech
            • 486
            The address book I exported from KM-3050 has to be imported to TA255c. Tried USB and did not work, tried Client utility and it does not support TA255c. It's sad that the customer has to copy / paste all those entries ... Disappointed at Kyocera that lacks such an on-demand feature
            • habik
              • 2013
              Check the Network Print Monitor its fun tool!
              Firmwares HERE
