Copystar 2050 Print job error
  • Frank L
    • 30
    When receiving a print job, and it is not the correct size paper and machine comes up print error just because of the paper size, is there a way for it to print on the paper that is in the cassette without it giving a error code? Thanks Frank
  • cbs
    • Apr 2011
    • 86
    Re: Copystar 2050 Print job error
    Yes, press the PRINT button, select GO from the display panel, and press the OK button.
    • Frank L
      • 30
      cbs is that the print button on the copier itself correct? Also the go and ok from the machine ? Thanks Frank
      • Frank L
        • 30
        How do they recognize this problem when all the machine tells you is that there is a print error? Why can't it be more descriptive. Thanks
        • cbs
          • Apr 2011
          • 86
          Yes, it is the PRINT button on the copier (left side of keyboard), you scroll down the display to highlight GO, then press the OK/ENTER key on the copier keyboard.
          I agree this is a poor user interface on this series of machines (and the "dressed up" 181/221 series as well).
            • 22932
            I used to get a bunch of service calls on this particular issue. My customer was sending A4 originals to 11" x 8 1/2" MFP. For my situation, Auto A4 did the trick.
            Like cbs says, it's not the easiest display to understand. My customer was re-booting the machine, which killed the print job. So they thought they were fixing something, until the next time. =^..^=
