We have a client that would like to be able to walk up to the machine and select black and white, but have to put in a code for color. The kicker is that they want the same for the print side. Print with no codes or resitrictions when using black and white, but then want to be prompted for a code when using color. Any Ideas ?? color lock will only work on the walk up side, and access lock print restrictions flat out don't work while using the domain feature. Thanks in advance !
Color Lock / Access Lock
Re: Color Lock / Access Lock
AFAIK, it's all or nothing. The best solution in my estimation is a code for B&W, and a code for color. Or, individually settable rights with each user having a unique job account code, but all users entering codes. Somebody correct me if I'm wrong: I think Ricoh does it this way, but not Kyocera. =^..^=If you'd like a serious answer to your request:
