Restoration of initial adjustments KM 5050,KM C3232E
  • Mr.Rain
    • Mar 2011
    • 6
    I have made dump by command U21 of the password of the manager in ' Command Center '.
    When I have printed the statute page I have readings of quantity of a toner were gone and the model of the device has exchanged on 2G-50, and should be KM-5050 how it can be corrected?
    • 23008
    Re: Restoration of initial adjustments KM 5050,KM C3232E
    For starters, you'll need to reset the machine destination U265 to 02 for KM, or 66 for Copystar. That will bring back your toner levels.
    Here are some of the other standard settings you may have lost:
    Enable LDAP: 10871087, 508, Start, ON, Start, Stop
    Set Destination: 265, Start, 66, Start, Stop, 001, Start
    Re-enter Printer IP: Printer, Printer Menu, Interface, TCP/IP, Change, DHCP to OFF, Bootp to OFF, enter IP address, enter Subnet Mask, enter Gateway.
    Copy default to B&W: System Settings, Copy Default, 4000, Auto Color to B&W
    Enable Corporate address book: System Settings, Scanner Basic, Corporate Address Book, Change to ON, enter IP address of LDAP Converter Utility (currently xxx.xxx.xxx.xxx).
    Re-enter Scanner Settings via Web Interface.
    At Copier, set Host Name: System Settings, Scanner Default, Scanner Settings, Host Name, Change to KM + last six digits of the MAC address (case sensitive, as printed on the scanner card).
    Create One User: System Settings, Scanner Default, Register, set #001 email as Department@copytechnet.com , set Display name as Department Name, Complete Entering key.
    Turn off Display Sender Screen: System Settings, Functional Default Setting, (Skip) Selection Of Sender (users), Change, set to ON.
    Set Output Trays for Copy & Fax:Set Output Tray for Printer:
    • Mr.Rain
      • Mar 2011
      • 6
      Many thanks, has earned all. I have only a question, I in service have not found codes for command U265.
        • 23008
        Are you saying that there is no U265 listed? I'm sorry, I don't understand.
        Oh, one more thing. The previous post was specific to the CS-C4035E (cut/paste). You'll have to substitute the correct CS-C3232E admin password. =^..^=
