Can the cs-2550 scan to smb if so how do i set it up
  • a.mart
    • Aug 2025
    If so how do i set it up, or it only do ftp.
    • 23009
    Re: Can the cs-2550 scan to smb if so how do i set it up
    I'm not absolutely positive, but I don't think SMB scanning is possible. Scan to SMB is specifically not mentioned in the release bulletin, only PC (FTP) or Email. =^..^=
    • copygirl
      • 75
      No scan to SMB. It has to use the scanner file utility.
      Ginger
      • kyocera.team
        • Aug 2010
        • 126
        scan to PC only there's no scan SMB
        • Scanner Crazy
          • Sep 2012
          • 12
          So how can you use scanner file utility if the computer can't connect to the scanner. Tried over and over again to change setting as suggested but alway get message "can't find scanner" or "communication protocol error". Had it set up fine before, but recently changed modem and router and can't get it to connect now. Using Comcast modem to Belkin router, both cables for printer plugged into Belkin Router. Used address book to register, but not sure it registered. Can't get Address Editor to connect to scanner, get above errors. Can't use scanner file utility because it doesn't see the scanner. Can anyone help?
          • monstott2010
            If you are trying to use Windows to connect to the scanner it won't work, it doesnt install as a device on the scanner list... you have to have the scanner connected, use the scanner file utility, the correct folder structure and have to have the correct settings in your firewall to allow the connection.. not too complicated, but may be much more effective to have a tech install for you
