Kyocera KM-3035
  • pkleinams84
    Kyocera KM-3035
    I aquired this from an office I shut down. There is no service contract and showing a format error Hard disk on the display. any thoughts ?? I am not a tech, just a user
  • techman
    • Dec 2007
    • 49
    Try this first
    Try updating the firmware if that dont help you may need a new hard drive.
    • kyoceradude
      The Great Gazoo
      • Aug 2006
      • 442
      Does the machine have a HDD in the print system? If so unplug machine and remove the 2 screws, remove the HDD.
      My mission here on Earth is to help all you Dum-Dums!
      • russmacman
        Try this
        Go to the printer button, look for Hard drive and format it. Say sure and wait. Its the printer HD on the right side that giving problems. If you want, unplug machine and plug the hard drive / sled out of the machine and see if the format error is gone. The machine has a print system in it right? If not its the copier HD and that also can be formated
          • 22927
          rusmacman is right on the mark. Try formatting the hard drive first. It usually takes 4 to 5 seconds. If it fails turn off, unplug copier, & remove the hard drive. If the error disappears you can replace the hard drive, or run without it if your print jobs are not too terribly large. If the error remains it's probably the print system that's shot. You can copy without it, but obviously can't print.
          • leroyal
            Expert on The Obsolete
            • Sep 2007
            • 156
            You can replace it with any Notebook Hard Drive.
            I know what I know better than anyone else knows what I know.
            • knightfall
              • Jul 2006
              • 633
              the hard drive is gone it can not format (never saw the format work properly) just remove the hard drive from the print system on the back bottom right of the km-3035 will see a black knob on a plate held on by 2 screws remove the hard drive with machine off. It can operate without a hard drive but you can replace it with any laptop hard drive (20gb).
              Get your facts first, and then you can distort them as much as you please.
