scanning
  • luis8832
    • Dec 2008
    • 250
    scanning
    Looking to set up scan to smb from a km-3050 to windows 7 home premium. Anybody out there been successful doing this and how? does anyone have a step by step? Thank you all in advance.
  • tech.gasm
    • Sep 2010
    • 39
    Re: scanning
    Its configuration is no different from XP unless you've proved otherwise since all entries are made on the scanner browser page.As for sharing,right click the destination folder,...properties..sharing(assign access permissions) ...security(assign access permissions) & exit.
    let me know what you know & then we can move on from there...(all this on the assumption that u r not totally new to this).
      • 22743
      Re: scanning
      I think I read somewhere that Win7 Home will not SMB. Can anybody confirm this? =^..^=
      • aodtech
        • 194
        Re: scanning
        Windows 7 has no problems with SMB scanning. From Home to Ultimate. You just have to know which settings to check for. The funny part is whenever I get an error scanning to 7 or Vista, I know where to look and it's almost always the same thing. Whenever I am having trouble with XP, those settings aren't present. So I'm like where the hell do I go from here? The only SMB problems I have had with the Falcon 3s is using the host name to scan. I almost always have to use IP address. Falcons 2 & 4, no problem with host name.
