km 5050 noisy and jamming
  • Iman
    • Jul 2008
    • 57
    Hi all does anybody know of any known problems regarding jamming and noise on this model. The noise seems to be coming from the reg unit as i can hear it slip causing noise .I have also noticed the gear which drives the reg unit seize n stop too which results in the slipped gear noise and jam at the same time. I didnt get time to strip down the drive section yet but will be returning to the machine and thought i would ask if anybody has seen this problem.
    • 23008
    Re: km 5050 noisy and jamming
    What jam codes? There are too many possibilities to start speculating on this information. =^..^=
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      Probably the double gear on top of vertical feed unit is worn out
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • ES-OGT
        • Aug 2011
        • 129
        I haven't seen it on these series of machines but I did see it on Falcon 2's (3035, 4035, 5035). What we found was one of the gears was wearing on it's shaft on the back side of the inner door on the conveying area. If you look below the reg roller on the back side you'll see what I'm talking about.
        We usually try cleaning the shafts and putting a little lube on them to keep them from squeaking. If that doesn't work replace those three gears. They're really easy to replace.
        • Kidaver
          Ghoulscout
          • Apr 2011
          • 912
          I've replaced 4 or 5 middle feed units on these models in the last 2 months....end users will slam the side shut and crack the plastic on the left side of that feed unit and eventually it just breaks off....
          "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
          • kyocera.team
            • Aug 2010
            • 126
            agree just i can add one more thing also middle feed unit
            • RWAFA
              • Aug 2011
              • 68
              they a different causes,try to check al th drive gears,also check th reg clutch,the clutch ch could have wone out.
              • Iman
                • Jul 2008
                • 57
                Hi all thanks for the responses. Just to let you know I got a chance to spend some time on the problem and after stripping the vertical feed unit from the machine I found three teeth on the gear which drives from the lower feed motor worn slightly. The gear is listed as -2fg06040 gear z21-z36 feed. Thanks for your imput
