TASKalfa 3550ci no coveridge on first 2/3 off paper 1 st. print from sleep mode
  • flimmer
    • Jun 2008
    • 30
    Does anyone experiance this problem. No problems when starting copying from sleep mode - only print mode 1. print missing image all colours for 2. thirds of A4 paper
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: TASKalfa 3550ci no coveridge on first 2/3 off paper 1 st. print from sleep mode
    Maybe firmware, Ver 3 just released
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • 23009
      That's the only thing that I can think of. =^..^=
      • Billy Bob
        USMC
        • May 2011
        • 51
        is print job sized correctly ?
        • taskalfaman
          • Nov 2009
          • 137
          hi,
          have the same fenomena on a TA-3050CI.
          changed dev k and dk k, transfer release motor no success.
          We changed the machine by a new one.
          now i'm going to change the HV-board.
          • vedder
            • 131
            Hi all, just wondered if this problem was resolved, i`m having (sort of) a similar issue, i`m getting no cyan whatsoever on the page, all other colours are fine, machine only done 100k ish, tried a new drum and dev unit, no change, im returning tomorrow with a transfer belt and laser from a doner machine, if that doesn`t work, i`m thinking HV board related?
            Any thoughts appreciated.
