KM3035 lite copies on 2nd sided of 2 sided copies only
  • bilyahn
    • Dec 2006
    • 1470
    Unit makes great 1 sided copies and prints. When I set it to do 2-2 or 1-2 sided (from DF or glass) the 2nd side is very lite for most of the copy until the last 1-1/2 to 2 inches then the copy is perfect again. Happens on every 2 sided copy the exact same way. Image on the drum looks good. Unit has 205K. Customer said it was working just fine and between one copy and the next it started doing this. Any suggestions? I will be adding the scanned image and machine info as soon as I get to work.
    Thank you for your time and effort in this matter.
    Bil
    Here is the scan. 2nd side, 1st side then machine info.
    km30352sidedcopyissue10-26.pdf
    The only thing I noticed was U053 setting is +7 instead of +9 for the default but I don't see how that has anything to do with it. Has me baffled at the moment as it doesn't make any sense that this should be happening.
  • ru4real
    • Aug 2011
    • 13
    Re: KM3035 lite copies on 2nd sided of 2 sided copies only
    Install a transfer roller.
    • Geo
      • 662
      Yep what ru4real said and try setting mm956 to old style.
      • bilyahn
        • Dec 2006
        • 1470
        Thanks ru4real and Geo. That fixed it!
        Have a great Veteran's day from one vet to all of you!
        Bil
        • taskalfaman
          • Nov 2009
          • 137
          just update the machine to the lateste version.
          best regards.
