Kyocera 255C Squeaking when Idle
  • Dr.silver
    • 38
    I have a 255c that squeaks loudly. I have never heard it when running the copier. The customer calls the Office and says it's Squeaking when its Idle. I thought fans but all are run quiet but then I thought Waste toner? I have no clue I am headed there again Tomorrow anyone have this problem or some Idea I can have before going out to it?
  • Zackuth
    • Aug 2009
    • 448
    Re: Kyocera 255C Squeaking when Idle
    There is a bulletin out B227-2KZ-0009 that deals with abmornal noise. I think that the tech I work with had this problem and found the bulletin. He ordered the parts recomended (which are back ordered). You might want to look at it.
    B227-2KZ-0009.pdf
    If at first you don't succeed, redefine success
      • 23008
      The implication here is that the the exit guide is warping as a result of fuser heat, and the friction between the shaft and the fuser guide is the squeak. Also the exit rollers (and fuser) must also be turning slowly at idle to minimize flat spots on the pressure roller. I thought we were done with machines that rotate the fuser at idle. =^..^=
      • B0265
        • Jan 2007
        • 718
        The main reason for the fuser idling is that this model use induction heating, and that is something that I think we will see a that a lot of in the future.
        • Dr.silver
          • 38
          Sweet Thanks I am going to the account today I will tell yea if it works. Thanks again for the advice!
