C3200 with New TASKalfa 181
  • kaborwen
    • Feb 2010
    • 146
    [Error Code] C3200 with New TASKalfa 181
    Hi,
    I have an error code C3200 with a new TASKalfa 181. I just take it out from box and connect. It's the third machine I get this problem. The first one, I clean mirrors and exposure lamp, ivent it's new, but nothing.
    Thanks for help.
    PS: Copy is light, but printer status page is ok.
    • 23006
    Re: C3200 with New TASKalfa 181
    I have a hard time believing that you have three defective machines with exactly the same problem, new in the box.
    Have you considered the AC power you are connecting them to? Dirty AC power can produce a wide range of unexpected errors. What does the power quality analyzer say?
    How about environmental temperature? Is it cold? A cold Xenon exposure lamp will light dimly or slowly. And there may be condensation on the CCD, lens, or mirrors, where the lamp intensity is monitored. =^..^=
    • kaborwen
      • Feb 2010
      • 146
      There is no external problem because I change the machine and the last one working correctly in the same place. So when I pull out the Lens cover (metal), I don't have the code again but copy is not good (that is normal).
      • Eric1968
        • 2458
        This must be an environmental issue. Must be temperature or humidity related, like Blackcat says. 3 machines, new, all three C3200? Hard to believe.
        • kaborwen
          • Feb 2010
          • 146
          You all right. There is a storage problem, humidity condensation on CCD and can not be clean. We have to change it, so we ordered a new one.
          Thanks all.
            • 23006
            Congratulations! This is an unusual situation. =^..^=
