about kyocera 4050
  • raztech
    • Dec 2008
    • 88
    about kyocera 4050
    the copier works just one cassette paper,it doesn't recognize the seconde one,I have checked for the hardwar systeme ,it was perfet ...
    I Think about softwar ....
    would you like to help for more solutions..
    best regards
  • Eric1968
    • 2458
    Re: about kyocera 4050
    Perform U906 (Reset Disable Function) to reset possible errors with the paper trays.
    • rashid120
      • Jun 2010
      • 76
      Engine PCB got shorted because of Lift Motor.try U906 if problem not solved please change Engine PCB and Lift Motor.......
      Thanks and Regards
      Rashid Iqbal
      • Eric1968
        • 2458
        Thanks and Regards
        Rashid Iqbal
        How do you know the engine board got shorted? Under normal circumstances a defective Lift Motor can not cause damage to an engine board. If U906 doesn't solve the problem, the next step can be to replace the Lift Motor (if that's the cause). In theory it can be the engine board, but in practice it's always a defective Lift Motor.
        • rashid120
          • Jun 2010
          • 76
          Try and change only lift motor it will never solve your problem(only if physically damaged) .i found 10 cases same.need to change engine PCB also.motor getting short because of excess paper usage in the cassette and effecting Engine PCB........slow movement of LIFT motor every time will lead you to check the short of Engine PCB.
          Thanks and Regards
          Rashid Iqbal
          • kkendric
            • 301
            First perform a U906 to re-enable a disabled cassette, if this does not work replace the lift motor, if this does not work, replace the engine board. On the KM/CS-3050,4050 and 5050 chances are if the lift motor is bad you will have a shorted transistor and an open load resistor bad on the engine board caused by the lift motor going south.
              • 23009
              I've seen a few cases of shorting lift motors damaging the drive circuit on Falcon III series machines. Relatively common, but yes try the U906 Partial Reset first. It's the same theory as the waste toner motors damaging the Engine board on the VoyagerE series. I've probably changed 50 engine boards and waste toner motors on the VoyagerE's just for that reason. =^..^=
              • ES-OGT
                • Aug 2011
                • 129
                Just something to try. I had a similar problem come up on a VoyagerE where I 906'd and replaced the lift motor but the problem still persisted. Before replacing the engine board I went ahead and reflashed the firmware.
                Machine works perfect now.
                • kkendric
                  • 301
                  Did you 906 it before or after replacing the motor ?
                  • ES-OGT
                    • Aug 2011
                    • 129
                    I did it when I first walked up to the machine after I verified there wasn't anything behind the tray and I did it again after motor replacement when it still didn't work.
