Email scanning problem in KM-C4035E
  • rashid120
    • Jun 2010
    • 76
    i encountered problem in KM-C4035E Scan through email problem..operating system is MAC.KM-5050 is working fine in that MAC environment.already updated firmware and checked all the possible settings but could not succeed .Machine is in the school.NO any other operating system(XP,WIN7) to test. any Idea? Folder scanning working fine.
    Rashid Iqbal
    • 23009
    Re: Email scanning problem in KM-C4035E
    Did you update the NS-30 firmware? It's not part of the standard combined firmware, and requires the IBVERUP utility.
    It probably won't make that much of a difference though. With scan to email there are four things that absolutely must be correct:
    1) SMTP server: IP or Hostname (IP preferred)
    2) SMTP authentication: either not required, or if required then username and password.
    3) Default Sender: Sender #1 must be assigned an address on the correct domain i.e.: scanner@copytechnet.com (it's ok if there is no real valid user with that address.)
    4) set Skip Senders to ON in Email Basic. This will save a few keystrokes for the users, not having to select the sender. The #1 sender will be used as the default. In the MFP's menu they abbreviate this item, so it's a little confusing. It makes more sense in the Web Interface where it's spelled out completely. (I hope I didn't get this backwards ... )
    #1 and #2 are absolutely crucial, and of course, I can't tell you what those should be.
    #3 is required for scan to email.
    #4 is a convenience.
    • rashid120
      • Jun 2010
      • 76
      Thanks Blackcat.all steps are done perfectly and checked many times again and again but no luck.only the thing is left is to update NC-30 Firmware.can you explain how can i update this firmware.i think we should use any utility software to update?
      again thanks for your feedback....
      Rashid Iqbal
      • habik
        • 2013
        Rashid Iqbal
        You have mist the hint in BlackCats advise: Did you update the NS-30 firmware? It's not part of the standard combined firmware, and requires the IBVERUP utility.
        Its a simple utility, run it, do a search and it will find any NS30 on network, I think it works even with wrong tcp/ip settings as long as it is connected. Then just browse for the .bin file of the firmware and upload. Simples! 8/)
        Habik.
        Firmwares HERE
        • kyocera.team
          • Aug 2010
          • 126
          Rashid Iqbal
          dear for updating the NC-30 you need to install packet driver (PDINST) then you should have IBVERUP and for sure the last firmware then when you run IBVERUP you will find any NC-30 in your network then you can update the firmware but be sure to uninstall (PDINST) after your update done
          good luck
          • rashid120
            • Jun 2010
            • 76
            good luck
            Thanks i will try this Sunday....
            Regards
