kyocera Taskalfa 221
  • Frank L
    • 30
    Question on the fax option does the flap that is clipped on the keypad assembly have any magnet or anything that signals it to respond? The reason for my question is I have one that I can't get to register the name and number on. Also if you push the print report key it will say abbrev in display, The reason is this machine that i have is missing the flap? Just seems wierd that this flap has anything to do with it. ? any help would be appreciated Thanks Frank
  • Zackuth
    • Aug 2009
    • 448
    Re: kyocera Taskalfa 221
    There is no magnet or anything I can discover. I don't know how it responds to that thing. The part number is 303MZ05010.
    If at first you don't succeed, redefine success
    • blsquires
      • Nov 2008
      • 342
      if its like the old facs the the piece that is missing (the flap)has a pip on it that hits a tiny switch in the middle at the top that is just above the on hook button. when the flap is turned to the left it hits the button and allows registration.
      hope this helps
        • 23009
        hope this helps
        That's exactly it. There's a minute feature on the door hinge that operates a minute momentary switch on the panel PWB. And yes, those door are a regular replacement item. They often just disappear ... eerie. =^..^=
        • Frank L
          • 30
          Thanks guys appreciate it.
          • Frank L
            • 30
            Does anyone have one in stock that they can sell me? Thanks again
