FS-9530 add paper tray 3 message
  • subaro
    • Oct 2010
    • 1274
    Fs-9530 printer with pf-750 lct. when power up error message add paper to tray 3. check unit and found it will print when paper is loaded in left side of lct. Right side of lct is not lifting at all. swapped feed unit and right side will now lift, but not move paper to the left. This is a new printer, but the lct is used. I also checked for broken plastic, the one that hold the metal plate and it is ok. Anyone seen this problem.
    • 22984
    Check that the lift motor coupler is spring loaded, and moving freely. The plastic shaft lift motors will tend to twist like a helix, and bind the coupler.
    On a few I have taken the time to file out the coupler so it moves freely. On others I've just replaced it. =^..^=
      • 22984
      Reply
      • JustManuals
        • Jan 2006
        • 9838
        Re: FS-9530 add paper tray 3 message
        Paul@justmanuals.com
