Jam 52 KM3035
  • bilyahn
    • Dec 2006
    • 1470
    Jam 52 KM3035
    Machine was jamming randomly with jam 47 codes. Cleaned the 1 way gear in the turnover assembly and when I do 2 sided now I get jam 52 error with paper stopping at the first roller of the duplex section and the clutch is not starting, also cleaned the clutch. Unit has the internal finisher is it possible that I bent a pin getting the connector back in (took me quite awhile with that finisher in the way) that is causing this? Or should I be looking at something else? Problem was just random before I got my hands on it! LOL 1 sided copies are just fine, only problem when duplexing.
    Thank you for your time and effort in this matter.
    Bil
  • aodtech
    • 194
    Re: Jam 52 KM3035
    Isolate your problem. Remove the DF-78 (and do yourself a favor and throw it in the garbage!!) and see if the problem continues. In addition to cleaning the one-way roller to include the shaft and bushing I also clean the feedshift solenoid and make sure both sensors are clean from dust. Perhaps the one-way roller is on backwards.
    • bilyahn
      • Dec 2006
      • 1470
      Re: Jam 52 KM3035
      Thanks for the response! I would love to throw that internal finisher away! Will give your suggestions a try.
      Bil
      • bilyahn
        • Dec 2006
        • 1470
        Re: Jam 52 KM3035
        It wound up being a bent pin on the turnover assembly connector. Have to be a little more careful next time!!
          • 23010
          Re: Jam 52 KM3035
          I are my own worst enemy.
          Great find! =^..^=
          • bilyahn
            • Dec 2006
            • 1470
            Re: Jam 52 KM3035
            Great find! =^..^=
            Yep, just that little bit of lazyness! LMAO
