TaskAlfa 3050ci with "error code F1D6"
  • dynsam
    • Apr 2011
    • 21
    [Error Code] TaskAlfa 3050ci with "error code F1D6"
    hi guys, please need urgent help. the machine when booting up goes to self diagnostic and gives the "error code F1D6" and it stays there. cannot also go into service mode
    please need assistant asap
  • 20gaugeO/U
    • 554
    Re: TaskAlfa 3050ci with "error code F1D6"
    Is this a new machine you just unboxed or has it been in the field a while? The code is not listed in the service manual but generally codes in that area, you are looking at a board or bad firmware if you just upgraded it. Reseat connectors including Doc Processor if the machine was moved to a new location.
    Good Luck
    • dynsam
      • Apr 2011
      • 21
      hi, its been in the field. i did as per your instruction and updated the firmware and now it gives another error code"F000" it looks like the RAM. what would be your suggestion?
        • 22999
        F000 is definitely a firmware problem. My next try would be to replace the CODE DIMM, then re-load firmware. =^..^=
