Taskalfa 500ci, C2102 code
  • milldew
    • Mar 2010
    • 22
    [Error Code] Taskalfa 500ci, C2102 code
    c2102 code, seems to happen at first turn on in the morning, they clear it and will run all day or sometimes will code a few times a day, always resets and runs. The manual says CMY dv motor or drive system. Has anybody seen this problem. I dont want to tear into the drive unit. I did replace all the dv's, still codes. I got the motor but haven't replaced it, waiting for them to complain more or for it to stop altogether.
  • luis8832
    • Dec 2008
    • 250
    Re: Taskalfa 500ci, C2102 code
    I havent seen this problem per say, but this tech bulletin might help you out. Good luck and keep me updated
    • vmchong
      • Oct 2008
      • 22
      C-2102 error. Cleaning motor is turning very slowly. replaced the developer units themselves. developer units were very hard to turn. This resolved the C2102
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • komakino
          i have had this code with brand new devs out of the box make sure they turn freely before fitting to copier, other than that its new motor and its easy to replace
          • eddie110171
            • May 2012
            • 133
            I've had this code a few times. Before I replace anything, I take off the back cover and start up the unit while watching the the cleaning motors to see if they are all turning. If one is stopped, take it out and check the micro fuse, its probably bad. A little trick I learned from my Kyocera regonal tech rep. Saves a lot of time.
              • 23008
              Unfortunately that's not a definitive diagnosis though. I've seen bad motors that the fuse was not blown also. You'll learn more from swapping it with another. =^..^=
              • milldew
                • Mar 2010
                • 22
                Replaced dvs and problem solved, one was tight apparently. End of thread, thanks all for help on this.
