Kyocera km-3530 fax problem
  • gideon
    • 283
    This copier has a million copies. The error c1010 came
    up yesterday, upper tray lift motor. Order the motor
    and copier is using tray 2.
    Today the FAX quit, all send or receive is going to
    memory but didn't transmitted. Tried direct TX didn't
    help. I can on hook dial and the phone is ringing and have a dial tone etc but
    no transmission of the fax. Tried force sending no result. Any idea? Thanks.
    • 22999
    Re: Kyocera km-3530 fax problem
    I'd go through and re-seat all the connectors in the fax option. Pay particular attention to the ribbon cable. If they are removed improperly, i.e. just yanked out of the connector, the contact strips will peel up and curl away from the backing. When re-inserted the conductors will fold over and not make proper contact. =^..^=
