Scan to folder error
  • brancas
    • Jul 2009
    • 78
    Taskalfa 255 set up scan to folder (smb) worked for a while then customer called saying unable to scan.While troubleshooting machine scans were successful but were coming out as a full green page. Copies from platen glass and feeder were coming out black.Replaced main pub according to tec. Bulletin solved black copies.When attempting to scan to pc from DP after doing usual steps(select send,address book,ok) and pressing start machine beeps and does not pull doc. Installed latest firmware and was able to scan successfully for a few days until customer called again.Customer said this was the same problem that happened before main pub was changed. Any suggestions?
  • ignacio.cortez
    • Jul 2010
    • 176
    Re: Scan to folder error
    Is this MFP connected to a Surge Suppressor, if not, you might have some Power Issues.
    • luis8832
      • Dec 2008
      • 250
      I agree, you may have a power issue. I had an account where they had 2 KM 6030's, one always during copies or prints would throw intermittent blanks. I moved that unit to where the other one was. With the second unit same thing, checked the outlet and the voltage on the nuetral was to high. If no surge check the outlet voltage.
      • jmaister
        certified scrub
        • Aug 2010
        • 755
        Theres a qa on this scanner board ....sits behind the optics.
        Ours was blown...
        Idling colour developers are not healthy developers.
        • brancas
          • Jul 2009
          • 78
          Turns out it was a power issue changed the line conditioner from a triple lite LC 1800 to the Kyocera branded line conditioner no problems since.
