csc4035 fuser
  • nmfaxman
    • 1702
    csc4035 fuser
    Had one tear up a bearing on the tension roller. I had another bearing, but now it is wrinkling the copies.
    My question is, do I have to replace the whole unit or can I rebuild this one?
    $600.00 is pretty hefty price for a new unit.
  • Zackuth
    • Aug 2009
    • 448
    Re: csc4035 fuser
    Checked the KM4035 parts list and you can buy parts for that model. The part number for the bearing is 2FG20230.
    If at first you don't succeed, redefine success
      • 22927
      Re: csc4035 fuser
      I think that you're talking about two different models The VoyagerE: CS-C4035E is completely different that the FalconII: CS-4035
      Yes, FalconII fusers can be rebuilt. VoyagerE fusers do not have individual parts available, yet I've scavenged together 30 or 40 of these over the years from scrap units.
      High fatality parts are the fixing belt, foam roller, bearings 688ADD (on the foam roller), Use the new style thermal fuse, heat roller, teflon coated and plastic inlet guides, exit guide front and rear can both warp.
      If you're not sure which model your scrap fuser came from, check the serial number: KXD... & KXR... are for the CS-C4035E. Lower speed models are all the same for VoyagerE and Voyager, and start with KXN...
      I can prepare a fuser in an hour. It seems worthwhile if you consider the cost. =^..^=
      • Zackuth
        • Aug 2009
        • 448
        Re: csc4035 fuser
        I saw the 4035 without the "e" and thought it was the b/w model with an extra letter inserted.
          • 22927
          Re: csc4035 fuser
          The $600 price tag gave it away. I am constantly confirming with dispatch: FalconII or VoyagerE?
          • nmfaxman
            • 1702
            Re: csc4035 fuser
            I checked the parts manual and it just shows a number for the fuser. Precision Roller said there was a kit for it but it was more expensive than the fuser itself.
            I guess I will keep the old one for parts.
            Thanks guys.
            It was the sponge roller bearing that gave out, I had one from a Ricoh that fit and the fuser ran, but now the copies are wrinkled.
            I tried messing with the pressure screws, but it didn't work.
            Oh well now I am out $600.00 on a $75.00 a month contract.
            • Zackuth
              • Aug 2009
              • 448
              Re: csc4035 fuser
              At least it'll be paid off in 8 months.
                • 22927
                Re: csc4035 fuser
                Be thankful that Kyocera did eventually resolve all the issues with the fuser. New style thermal fuse, improved bearings, etc. There were 15 or more variation on that fuser until they got it right. When these machines first came out, I would get 100K or less from a fuser typically. That's why I started scavenging together spares. =^..^=
