Taskalfa 300i grey patch through feeder
    Hi all
    Brand new just out of the box Taskafa.
    Copies off the glass and reports are perfect but a copy through the feeder has a grey patch on the trailing edge.
    I have taken the slit glass off and looked at the optics all looks good, could this be a feeder height problem? the feeder looks like its sitting level.
  • copymech
    • Sep 2011
    • 196
    Make sure the shoulder screws for the feeder brackets are tight, if loose they will cause all kinds of problems.
      • 23010
      Re: Taskalfa 300i grey patch through feeder
      Is this a cardstock original? heavy cardstock will not be able to wrap around to the slitglass without doing a little flip at the end. =^..^=
        Sitting above the slit glass in the feeder is a metal plate called 'guide reading' in the parts list. I took this off and placed it on a table to see how straight it was. I could see a gap of approx 1mm in the middle. I straightened it so it was perfectly level, fitted it back and the problem vanished.
