CS-300i with DF-670(B): original skew
    • 23009
    I thought this was going to be one of those 3 minute service calls. Snug up the cassette guides, show the keyop, then move on. But nooo ...
    Print skew was unmeasureable (less than 1/8 mm), OC (off the glass) skew was 3/5 mm, and DP skew: 3.25mm
    Wow that last one is impressive! I'm measuring image skew on 8 1/2 x 11 letter originals on same paper, measuring the subscan distance between the leading edge and the centerline on my test original, the difference between measurement at the front compared to the rear.
    I thought there must be something really obviously wrong with with this DP. The only really obvious thing though is that there aren't any mechanical skew adjustments, or for that matter any other mechanical adjustments excepting left hinge height. The whole DP is just one big molded chunk of plastic. The hinges are intact, not bent or warped in any way. I guess the thing is just supposed to work just like it is, without adjustments.
    I did get a small improvement by bottoming out the hinge height. Now only 2.25mm. If I go the other way I can make that skew over 5mm very easily.
    Has anyone tried to address this? =^..^=
    Re: CS-300i with DF-670(B): original skew
    I had a problem with this feeder producing a grey patch on the trailing edge. Theres a metal plate where some feeders would have a platen roller. Take this off and place it on a table is it absolutely level?
      • 23009
      Flat, level. I thought of slipping a couple flat washers in between the mount to shift the contact point of those pressure rollers 1mm or so, up or down. No affect whatsoever. =^..^=
      • rashid120
        • Jun 2010
        • 76
        Dear Friend.
        To solve this issue you have to drink one cup of coffee.relax your mind for a while and start the work in this sequence..
        1: Adjust the Sim (U072) Adjusting the DP Center line.you can decrease the value and increase the value .you can observe where you can get good image near to your original.make a test copy and check.
        it will not solve your problem but you can come to near end.
        2: Adjust the SIM(U071). Adjusting the DP scanning timing.this simulation is controlling the speed of DP scanner motor.
        same you can increase and decrease the value and make test copy.
        3: In the last you can try the Sim(U068).
        Hopefully these steps will help you to solve the issue
        Thanks and Regards
        Rashid Iqbal
        • Venom
          Technical/IT Support
          • Nov 2009
          • 765
          Which DP is on it...pretty sure there is a skew adjustment at upper side of right hinge if it is one I am thinking of. If doc feed gets pulled while moving copier, you can get gray banding down middle of copy and at lead and trail edge.
          IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
            • 23009
            ... I did get a small improvement by bottoming out the hinge height. Now only 2.25mm. If I go the other way I can make that skew over 5mm very easily ... =^..^=
            It was the only thing that actually helped, a little. =^..^=
