2050 w fax L
  • T911
    • Jun 2007
    • 628
    2050 w fax L
    This fax is locked up. What is the reset on this one. Turn off holding the stop key turn on to reset hmmm forgot. I don't want to do 600/601. Thanks
    • 23010
    Re: 2050 w fax L
    The only time I've had trouble with a fax sys L is when I was working on something else, and left a ribbon cable partially connected. I'd just go through the installation check list to be sure that everything is connected correctly. What objection do you have to U600/601? Are there hundreds of one-touch addressbook entries? They're not that hard to re-program. =^..^=
    • T911
      • Jun 2007
      • 628
      Re: 2050 w fax L
      There was alot in the ad book. Did a 600/601 and all good. Thanks
