KM-3530 regarding web interface password
  • goldencup
    • Nov 2008
    • 366
    Hi. I have a machine Kyocera Mita KM-3530. I connect it to web interface. I would like to ask what is the default password for administrator and print operator? Thank you very much.
  • koni123
    • Sep 2011
    • 13
    Re: KM-3530 regarding web interface password
    Hi
    No password ,try 6482
    • goldencup
      • Nov 2008
      • 366
      Thanks for the reply . I tried but no luck
      • russmacman
        Remembers 900d (redtop)
        • 19
        Pull the printsystem board out, if there is a hard drive pull that. On the board where the drive will be you will see a jumper on 1 leg (keeps from getting lost) take jumper and short out I believe its #2 side. Install without HD. Start machine, wait for ready screen. Shut down and put jumper back. Print system should be back to factory. If not try jumping #1 (same type of setting for the scanner card) Good Luck. Russ
        • rashid120
          • Jun 2010
          • 76
          user name: admin
          password: admin
          Thanks and Regards.
          Rashid Iqbal
            • 22930
            There is no default admin password. The default is no password.
            Don't you love these security geniuses that set passwords then change jobs or just forget what they chose?
            My recommendation? Clear the webpage with an engine reset, then do not set a password. =^..^=
            • Venom
              Technical/IT Support
              • Nov 2009
              • 765
              also...Firefox won't work properly...use IE
              IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
              • DWise
                • 895
                I haven't had any issues using Firefox... I despise IE
                Do for one what you wished you could do for everyone. - Andy Stanley
                • Venom
                  • Nov 2009
                  • 765
                  I hate IE too but many times when using firefox, had login issues etc.
                  I use firefox for everything not Kyocera related.
                  • Venom
                    • Nov 2009
                    • 765
                    That printer NIC may have ability to clear, jumper sw 2, turn on, turn off, put jumper back
                      • 22930
                      There was a scan card firmware update that corrected the problem with Firefox. Sorry, I don't remember the version. =^..^=
                      • goldencup
                        • Nov 2008
                        • 366
                        Thank you very much ...no password
