task alfa 221 printing problem.
  • tullio
    • Feb 2012
    • 268
    printing problem.thedrumand'new.I changedthe cartridge,the sameproblem. not accennde no lights.
    urgent
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: task alfa 221 printing problem.
    Look at the developer magnetic roller...may need to clean it
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • tullio
      • Feb 2012
      • 268
      and'statepulito.stessoproblem.
      when you replace thedrum,there is'some procedureto do
        • 22930
        • tullio
          • Feb 2012
          • 268
          when youget upanddo200-300stampe.poliifI put thetoner and'ok.thenthe sameproblem.
          • habik
            • 2013
            Firmware
            New dev unit + OEM toner + U130 should solve it
            Firmwares HERE
