Kyocera KM 2020
  • kalaris
    • 70
    Kyocera KM 2020
    Hi!
    Should I adjust the 2020 KM. Someone might indicate the procedure for printing adjustments after entering codes with 1087/1087.
    Thank you
  • Eric1968
    • 2458
    Re: Kyocera KM 2020
    What would you like to adjust?
    • kalaris
      • 70
      Re: Kyocera KM 2020
      Sorry for the translation. I mean the procedure to obtain the release of all the technical codes to make the necessary adjustments.
      • Eric1968
        • 2458
        Re: Kyocera KM 2020
        With sim 000 you can print all machine settings.
          • 23010
          Re: Kyocera KM 2020
          I think what Eric is getting at, is that most Kyoceras require very few image quality adjustments. Most often adjustments are made to compensate for worn out consumables like drum, primary charge, developing unit, etc. Maybe you should look at the condition of the consumables first. =^..^=
