Km3060 w/ dp670 doc feeder
  • dbrownlee
    • Sep 2005
    • 197
    Have a customer with this machine combo. The ADF has started to drop down when open. Does anyone know if there is an adjustment to the spring tension before I order a new hinge. They are 60 miles away, so I would like to do it in one trip if I can. Can't find anything in the service manual.
    Thanks, Dave
    GO TIGERS!!
  • copymech
    • Sep 2011
    • 196
    Re: Km3060 w/ dp670 doc feeder
    there are no adjustments for the hinge. the shoulder screw that mounts the hinge to the copier will become loose. other than that youll have to replace the hinge.
    • dbrownlee
      • Sep 2005
      • 197
      That's kinda what I figured. Thanks
      GO TIGERS!!
        • 22999
        Yup. It's just a couple of heavy duty springs on a slide mechanism. Most often the plastic parts break, but rarely I've seen a broken spring. =^..^=
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • dbrownlee
            • Sep 2005
            • 197
            OK then I will order up some hinges. Thanks, Paul, but already have all the manuals available for theis machine. Thanks again all.
            Dave
            GO TIGERS!!
