3500i Dual Fax
  • Mooseface2r
    • Jan 2011
    • 114
    3500i Dual Fax
    Does anyone know how you choose which fax number to send from.
    I have two fax boards installed with two lines both ifferent numbers but can't see where to select what fax number I want to send from? Any ideas?
    Cheers guys.
    • 23010
    Re: 3500i Dual Fax
    It's always the fax PWB in Option #1 slot that sends. Assign or connect whichever number or line you like. You cannot switch back & forth or have multiple sender phone numbers.
    This came up the other day on a Konica Minolta. The customer expected that two tenants sharing the costs of the machine could call out on different lines as needed. That particular machine allowed choosing the TTI sender name from a list, but the sending number had only one setting. That model had a sim for choosing option #1 or option #2 fax board as the sender, but not both or switchable moment by moment.
    Was that clear? =^..^=
