CS-4550ci Engine board
  • Dave10
    • Jul 2008
    • 197
    [Error Code] CS-4550ci Engine board
    This is a continuation of an earlier post, but a new problem. I would like to know if you guys are having problems with these boards. I had to replace an engine board on a brand new machine because it wouldn't recognize the bridge unit in the adapter kit. I eliminated everything else and ordered an engine board. When I put the new board in, I got a C-4101, which is an LSU code. I switched the old board back in, and I now have a C-F040, communication problem between engine and main boards. Each board is consistent, no matter what I do. I think I was sent a bad board, and the old one is developing more and more problems. Anyone else having issues like this? It's driving me nuts.
    • 22999
    Re: CS-4550ci Engine board
    I've never had to change one. Sorry, can say one way or the other. =^..^=
    • habik
      • 2013
      Re connect all connectors on PWR supply and all boards pretty much, then format the HDD.I had this issue once, and it was down to a loose connector. I would not be surprised if it threw different codes for different parts if the connection is loose or not proper.Keep us posted how is it going.
      Firmwares HERE
