CS-420I C2000
  • yakyitz
    • 244
    CS-420I C2000
    When copying ldr at 100% as soon as the lead edge reaches the exit it errors out. ltr no problem and get this when copying from ltr to ldr at 129% no problem. Also doesn't make a difference which paper source the ldr is feeding from tray 1,2 and MP. firmware is the latest.
    • 22999
    Re: CS-420I C2000
    Are the paper trays programmed to a specific paper size ... like letter?
    You have two choices:
    1) select Auto Inch
    2) select ledger for the tray you'd like to use.
    Either will do. =^..^=
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      Re: CS-420I C2000
      I've seen seizing drum unit cause that and could also be seizing press roller bearings.
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • yakyitz
        • 244
        Re: CS-420I C2000
        Blackcat, I've tried both settings and still it will only feed ldr if zooming an original ltr to ldr at 129% if the original is also a ldr copying ldr to ldr at 100% it codes out c2000 no jam code and it doesn't matter whether it's tray 1,2 or MP ltr from all trays feeds fine.
        Venom, if it's the drum seizing why does ltr multiple page run feed ok?
        I appreciate your input just trying to get the most info as it's a 3 hour drive to the customer
        • Venom
          • Nov 2009
          • 765
          Re: CS-420I C2000
          I've seen 2 machines that intermittently threw c2000 codes and both times was drum was hard to turn, it was weird.
          • eddie110171
            • May 2012
            • 133
            Re: CS-420I C2000
            Print the release notes for the current firmware and print out the maintence report U000 and check to see if all the firmware actually loaded. I've had times where some parts loaded and some didn't and caused bizzare things.
            • Troutfink
              Re: CS-420I C2000
              Had a 420i throwing a C2000. After close inspection it was seized drum unit. It would run a few hundred pages then the C code would get thrown. First time I've ever seen a seized drum on a Copystar. I'd check to see if the drum moves without a lot of resistance. If it doesn't you have your answer.
              • Tonerkiller
                • Oct 2012
                • 668
                Re: CS-420I C2000
                Replace the drum. I have seen this also.
                • thekeg19
                  • Jul 2008
                  • 29
                  Re: CS-420I C2000
                  Drum/ Km 4050 throw the same code. drum seized.
