KM 5050 Is asking to be sitched off and then on exactly every day at 16:00
  • habik
    • 2013
    Has anyone had this before?
    So far only U906 and waiting for customer to send me scanned maintenance reports and event logs.
    Firmwares HERE
  • habik
    • 2013
    Re: KM 5050 Is asking to be sitched off and then on exactly every day at 16:00
    It looks like that the U906 helped for now.
    Machine had a lot of C-codes if that interests you:
    C0630:001
    C0800:002
    C1010:001
    C3200:005
    C3300:008
    C3310:002
    C5300:006
    C6020:002
    C7300:003
    C7410:002
    C9050:002
    CF14F:004
    CF247:001
    CF26F:019
    CF620:005
    Firmware
    Main MMI : 2GR_2000.032.002 2GR_7000.032.001
    Engine : 2GR_1000.018.001 2GR_1100.001.007
    Scanner : 2GR_1200.006.001
    Dictionary : 3JX_9500.002.002
    May need re-flashing with the latest firmware. Will keep you posted.
    Firmwares HERE
      • 22999
      Wow! That's a plethora ... no, a cornucopia of errors. I was paying particular notice to the cf14f, cf26f, cf620, C3300, C3310.
      I'm thinking either power supply, or AC power quality, in that order.
      On second thought, make that AC power quality. Set up that Power Quality Analyzer. =^..^=
      • habik
        • 2013
        Many Thanks,
        ]Been theatre yesterday and found that the AC plug was getting to close to someones feet and the outcome is accidental power plug release and therefore a lot of codes related to AC power issues.
        I have formatted HDD, flashed FW and then I was getting constant C3300...it took me a while, that shading corrections need re-adjusting and could not figure out, until I looked down the optics which were cleaned not a long time ago.
        Optics were absolutely dirty..whether someone try to blow inside I don't know but after cleaning them up ..it works for now as a champ.
        Hopefully it is fixed...Will find out when I go there to do Full PM kit..as it is clocking 700k.
        Cheers Blackcat for your input. always good!
        Firmwares HERE
          • 22999
          700k on the first PM? Amazing. =^..^=
          • habik
            • 2013
            Except feed assemblies we try to keep the fuser and dev and drum to run bleeding dry and used to the bone.
            As long as customer does not complain about quality issues we try to make the most out of it. The fuser is really worn out..and has a line coming under one sep. finger but it have not affected quality dramatically and is not noticed on prints..soo quite alright for now.
            Firmwares HERE
              • 22999
              I've got a Konica Minolta that's pulling a C28-11 error twice a day. First occurrence is between 6:56 and 6:59 every single day. The second occurrence is between 15:50 and 16:01 also every single day. The real confirmation is that often the machine is idling. It's not even running most times when the error occurs!
              I've got the power quality analyzer over there right now recording. I'm anxious to see the results. =^..^=
              • habik
                • 2013
                Hey BlackCat
                Any results on the Power analyser?
                Firmwares HERE
                  • 22999
                  I got a power sag at the exact second that the error recorded on the copier, every single time. The first time around the customer ran a dedicated line to a newer panel. The problem is, the AC power was dropping below 206 AC from the power company. After a second set of recordings, the customer contacted the power company. I have not had another code on that machine since that day. Not any code. The Management Report is clear since that day. =^..^=
